gmtech16450yz
- SF Bay Area
- Limited S
Ok I said I was gonna do it, it's done! The greatest, most over-engineered throttle/shifter assembly put on a Yamaha. And probably the most time consuming mod to my boat so far!
I haven't actually taken the boat out yet to try it, but it looks like it should work like I wanted it to. Here's some pictures of the stock throttle to clearly show why they suck. lol.
This is in the neutral position, throttle at idle, bucket at neutral.
This is to the first detent, the bucket is opening towards forward, but the throttle is still at idle.
This is at the point the throttle starts to open. There is no detent here, you really have no idea where this spot is when moving the levers. If you tighten up the drag, you can feel the throttle when it starts to move, but it's still often a surprise when you first open the throttle. Unsafe and actually dangerous if you ask me. It was literally the first issue I had with my boat. The first time I went to pull away from the dock, I ended up giving it way too much throttle and darn near launched the boat into the dock.
And lastly, here's full throttle. These last two pictures show the total range of movement to control throttle from idle to wide open. Pretty narrow huh? Horribly narrow. Stupidly narrow. haha.
I'm going to break this up into a few different posts because there's gonna be a bunch of pictures...
#coolmod
#coolmod
