- Raleigh, NC 27614
- 242X E-Series
This is intended to be an ultimate leak finding thread! If you have a leak that isn't covered in this thread, reply and @Julian so I get notified to update it.
First Question:
One member used baby powder sprinkled in his bilge as a way to more easily spot where water is coming in. Using your phone with the light on and recording video in the bilge is also a good approach.
Also began an FAQ on leaks
Links to threads on boat leaks:
First Question:
- Is the water in the bilge hot? If cold, move to section A, if hot move to Section B.
- Loose or poorly sealed through hull fitting.
- This could be the main drain plug itself, shifter cable, bucket cable, speedo, depth finder, or anything screwed into the boat below the water line.
- One (not fool proof) way to quickly check for this is to put the plug in the boat while on the trailer and stick a hose in the bilge and fill the stern with water while looking for leaks (don't go to the point of touching the oil filter with water...but you do need some pressure). If this produces a leak outside...voila. If it doesn't, it doesn't rule out these fittings, but make it much less likely.
- Visually inspect all the fittings.
- Seal with _____(insert preferred sealant here--life caulk? 4200?)
- Scupper drain (especially for models where this drain is below the water line-24' models built after 20__ (need year) have scupper drains above the water line) may be cracked...often a problem in older 23' Yamaha models...the plastic hull fitting cracks and leaks (photo?)
- Broken seal around cleanout tray. Reseal with silicone or weather stripping. When you stop the boat quickly, water can get forced up the clean out tray drain tube into the clean out tray. If the hatch isn't sealed water leaks in there, and if the tray edge isn't sealed it will leak there too.
- Plugs not fully engaged. Water is flowing around them, up into the cleanout port and/or around the cleanout tray to get to the bilge.
- Intermediate Bearing leak, and another thread on bearing leak
- Leaks in the fittings at the point where the drive shaft enters the boat. This thread covers this (due to rope ingestion)
- Anchor locker drain-either has a leak, or the anchor locker itself leaks. This is especially a problem if you drive the boat with a bow full of people through a long no wake zone...it forces water into the anchor locker and fills it with water...which then leaks into the rest of the boat. On some model years the anchor locker drains weren't sealed and allowed water into the hull when the bow was loaded down and driving no wake speeds.
- If your speedo isn't working and it is a Pitot tube style....check behind the helm for water and connect the hose.
- If you have ballast bags, check the connector fittings for leaks. There is also a sillcock (valve) on the intake at the through hull that you can close. This would eliminate all but the through hull fitting itself as a leak source on ballast systems.
- If you are wake surfing and sink the rub rail below the water, the rub rails often aren't sealed well....check there for leaks. Also, the pop up cleats leak.
- If you beached with the stern very low and waves washing the swim deck, two things could be an issue. One-the rub rails can leak water through, or Two, the clean out tray may not be sealed.
- Some boats have had leaks in the clean out tube hose at the bottom. This would only leak when the stern was weighed down a lot.
- Many of our boats don't have drains hoses connected to the cup holders, so when water gets in them it goes right into the bilge. Some boats with swim deck cup holders have this issue. On mine they drain onto the swim deck, but if the hose comes off...then they drain to the bilge.
- The following thread covers leaks in the clean out tray and rub rails: https://jetboaters.net/threads/need-help-lots-of-water-draining-from-plug-on-17-212x.23345/
- Do you have a wash down pump or shower tank - check the fitting - some have found them almost completely undone!
- Check all the hose clamps and see if any are missing or broken.
- Check for cracks in the manifolds.
- Check for leaks on the intake of your resonator.
- https://jetboaters.net/threads/still-leaking.13046/
- https://jetboaters.net/threads/surprising-water-leak.13295/
- https://jetboaters.net/threads/impeller-jam-caused-serious-leaking.7274/
- https://jetboaters.net/threads/water-leak-from-engine-block.14405/
- https://jetboaters.net/threads/i-dont-think-water-is-suppose-to-be-there.5919/
- https://jetboaters.net/threads/water-in-my-bilge.12397/
- https://jetboaters.net/threads/repairing-damage-and-a-leak-caused-caused-by-a-rope-being-sucked-into-the-impeller.18078/
