djtech2k
- WV
- SX
I know this is a discussed subject here but I have a different question/thought about it.
I have a 2012 210SX that I bought in the fall and had it in the water like 3x. I noticed that the port engine RPM's would shoot up if I hit the throttle aggressively and after posting here, I learned it was cavitation. I read a lot here and asked a lot of questions trying to resolve it. In the end, I ended up driving it 2 hours to a recommended boat mechanic at a nearby lake. He took the pump out and told me that I needed a wear ring and a prop. He said that the prop was "burnt" from running it with the cavitation. Its going to end up costing in excess of $1200.
Now I am worried that the other engine is going to do the same or even worse. So my question/topic here is how can you avoid the things that cause this kind of issue? I mean I understand that something can get stuck in the prop and affect the gap between the prop and the wear ring, which I guess causes cavitation. How do you avoid something like that? I mean water has debris in it. There is no way to avoid it. The mechanic said that if you feel cavitation, you should stop running that engine immediately and not use it again until its resolved, otherwise cavitation will cause all sorts of issues/expenses.
So for me, I am worried that it will happen on my 2nd engine or even happen again in the one I just had fixed. What can you do to avoid this? How often is this expected to happen on a jet boat (cavitation, wear ring/prop replacement, etc)? My boat has about 150 hours on it total. So its not like it has a ton of hours for a 2012.
Any ideas/experience you guys have with preventing, detection, protecting, and so on, let me know. At this point I am worried about these engines/jets getting messed up all the time or having to stop running it while out on the water or whatever.
The mechanic did tell me to run the boat and that I did not have to baby it or anything. He only looked at the port engine that he fixed so he did not comment on the starboard. He also said that docking the boat and pulling it on the trailer would be MUCH easier after these repairs. He said it will drive like a new boat in those situations now. I did buy the Cobrajet fins but planned to install them myself to save $$ because low speed steering was so difficult before. Now I wonder if I even need them since he said it will steer so much better. Oh well, I guess its just another $400 and time to install them lol. #BoatLIfe
