Ronnie
- SF Bay Area
- Limited S
I bought a used PWC trailer a few weeks ago but ended up scraping most of the frame and salvaging the rest. Why? I didn’t conduct the proper inspection. The trailer looked ok but the bow stop was bent to one side as was the support bar it was mounted on, so I thought something or someone put a lot of force on the side of the bow stop. No big deal, my friend can fix that no problem and confirmed the same when he came over to inspect it.
When I asked him to detach, reposition and reweld one of the fenders because it was closer to the tire than the other fender he asked started to check out the frame with a square and quickly determined that the trailer frame was significantly bent. One side was 1.5” shorter than the other side and the short side was slightly lower than the long side. Additionally, the rust was so bad that in the frame past the spring mounts needed to be replaced. However, this too was feasible.
in the end I did what he said he would do if it was his trailer, kept most of the parts for spares or to rebuild the trailer in the future.
I could have avoided this if I had known how to properly inspect a trailer. Here is what I will do the next time around.
1. Bring a measuring tape and measure the distance from the tongue to each rear corner of the trailer. If the distances are not equal to each other the feame
2. Bring a square and put it into the corners made up of the frame and it’s cross supports. If they are not at 90 degrees the frame may be bent.
3. Take a close look at the bends in the frame which allow it to taper toward the tongue. they should look the same, to one up and the other down.
4. Bring a hammer to do the tap test, it should sound the same throughout the trailer frames length on both sides. Some rust may not be a big deal, it depends on how much of the frame needs to be replaced.
FYI I’m out $260 for the trailer and another $50 for new lights, wiring and a stern tie down but I have almost all the parts to rebuild the trailer including new tires and trailer jack. I have not priced out the cost of steel for the frame but suspect 16 feet of 2” x 3” won’t be cheap. I’d rather have the money and storage space back. I may rebuild the trailer if I sell one of my old waverunners or I may just include all of its parts in the sale of the waverunner.
