Throttle cable breaks
Why does brand new throttle cable brake on first time it's used?
  • New cable
    Votes: 0 0.0%
  • First time used
    Votes: 0 0.0%
  • Total voters
Joe k
Toledo Ohio
Sugar Sand
Hello new to the site and sport jets. We Bought a 98 tango, i found the shift cable was broken. Removed and replaced with new and when it was put in the water it broke again after giving it a lil gas pulling out of the channel any ideas why it would brake so soon? Any ideas would greatly be appreciated.........
Joe k
Murf'n'surf
Naples Florida
Are you sure that the cable broke? Maybe it popped off?
Was it hard to throttle up and you pushed through it? If so I would move your throttle body and throttle shifter separately and see what is frozen up and then dig deeper on the stiff parts.
Joe k
Toledo Ohio
Sugar Sand
When I got done Installing it and put in water.. When I give it throttle the throttle was shaking and jumping around then it stopped and after inspecting I found the linkage was broken where it threads into the steel shaft
