2devine
- Farmington Ct
- Limited S
I read on this site a procedure on how to fix throttle drop at speed. When I took off the cover I noticed two screws that appear to be an adjustment. When I tightened them up (finger pointing to screws) I found the throttles to be stiffer to apply. However, the left throttle has play side to side(left to right) enough that the RPM changes when you let go. I also noticed that this left side screw moves around a lot when you jiggle the left throttle where the right one does not.
My question is there something that loosens up inside the box to fix this? Is this what the other posts talk about or is this screw adjustment new to the 2012 and newer?
Thanks before I take anything else apart.
