Chase Worthington
- Wesley Chapel, FL
Completely forgot about that! (It has been a loooong off-season)Also, it nearly eliminates the throttle "fall back" that my model boat experiences.
I've been sold. Just like thrust vector vs cobras, I have put PP and Ridesteady side by side comparisons on specs and I believe Ridesteady is the way to go too.Don't want to sound like a Ridesteady salesman, lol, but I really love that thing - PP (perfect Pass) does not synchronize the throttles in our twins, but ridesteady does. You can have the two throttle levers far apart (within limits) and the system electronically synchronizes the RPM for both engines - it feels like magic.
I never tried throttle synch bracket gizmo as my throttles can be significantly apart to equalize the RPM, which I am very sensitive to. I love the engines humming in synch, sounding like a twin prop plane.
Maybe this is due to the keel design but in my '16 Limited the boat does not pivot when I have one in forward and one in reverse. I may try again this weekend but I have tried and the boat barely moves. Has anybody else in the newer boats been able to get their boat to pivot by having one engine in reverse and the other in forward?I have it, and use it mostly when launching out of no-wake speed. I disconnect it when I run close to WOT as my engines RPMs will not be the same when engaged, I will be adjusting throttle stops on the water when we get some better weather. As far as docking, I disconnect it as I may have 1 throttle forward and 1 throttle reverse to pivot boat in windy conditions.
Yep, it does not seem to work very well in the "keeled" new 240s.Maybe this is due to the keel design but in my '16 Limited the boat does not pivot when I have one in forward and one in reverse. I may try again this weekend but I have tried and the boat barely moves. Has anybody else in the newer boats been able to get their boat to pivot by having one engine in reverse and the other in forward?
