WildCatFan54
- Lexington , Ky.
- 242 Limited S E-Series
I am wanting to install a thru hull AC plug on my 240 to make access from the shore power easier. Preferably on the port side behind the wake tower ? This would be the closest point to my 2 batteries in the port side passenger storage area. My question is two part : I have looked at both the NOKO and the ProMariner plugs. The ProMariner is a little smaller (1 7/8") hole than the NOKO (2"). Has anyone had positive or negative results with either and #2 : Is the carpeted side wall in the battery compartment the outer hull of the boat OR is there dead air between an inner hull and the outer hull ? How thick is the fibreglass at that point ?I am open to other locations but I do back my boat into the slip and then raise the lift. My shore power is located on the port side rear and would like to use as short an extension cord as possible .
