- Panama City, Fl
- Other
Hey guys and gals,
JetBoatPilot has made an improvement to the Thrust Vector system for BRP Powered Jet Boats. This year, as a result of input made by some of the members of this board, we've added a rubberized coating to the cross member (actuator) of our Thrust Vector slow speed steering system.
This rubberized coating was added to eliminate the metal on metal contact being made between the reverse bucket and the cross member during certain operating conditions. Now, with this new coating in place, in the event that your reverse gate does come into contact with the cross member this rubberized coating is in place to minimize the potential for wear and cosmetic blemishing.
Single Engine Thrust Vector Install Video:
(The twin engine version is similar in its installation procedure but the bottom mount sheet metal is a bit different due to the connecting rod that ties the two nozzles together)
If you have more questions about Thrust Vectors for your Chaparral, SeaDoo, Scarab, or Glastron jet boat feel free to contact us through the website as well as through jetboatpilot.com.
Thank you to those of you who were instrumental in seeing this improvement become a reality. Once again we value all of your opinions and will always look to use your suggestions where possible to make your experience with our products more enjoyable!
@Julian @Bruce @ScarabMike
