To prevent sucking up debris, slow or fast?
Scott Potter
Central CT
Chaparral
VR
Just throwing this out there to get some opinions. I was out yesterday on the river and due to it being so early in the season, there was a lot of small sticks and debris on the water. I was able to avoid it all, but a thought crossed my mind. Which would be better at preventing debris from getting sucked up? Slowly gliding over stuff at say 5-12mph, or going fast, say 30+ mph?
MrMoose
Calgary, AB, Canada
Great question. I asked that same question to someone last year and they told me to go slow enough to allow the hull to displace the debris to the sides. I haven't tried it.
smashedheadcat
South Weber, UT
That is a pretty interesting question. I think it's really a matter of finding some sort of balance. On one hand, with an elevated impeller rpm, it should be substantially more effective in passing debris through it when compared to just idling. The caveat is that an increase in impeller rpm will draw a substantial amount of additional water and with it, more debris. The more debris that gets in there, the more chances you have of something sticking. However, it may be mitigated by elevated impeller rpm. It's tough to say, and I would love to hear experiences of jet boat veterans.
txav8r
Lake Ray Roberts, Texas
It is a question of a good number of things. Size of debris, on surface floating above, or just below surface, grass, wood, or other foreign stuff. And more than two schools of thought on it. If it is just some floating broken up wood, sure, go slow and let the hull push it out of the way. But at 50mph, it has to hit dead center in the intakes to get sucked in, and at that speed, there is a good chance that it can't make the turn into the jet intake and will just glance off and pass by. It is the high angle of attach, high rpm, turns and accelerations that will suck in the most. Over grass or weeds that are connected to the ground below the water, going fast has worked for me more than slow. But if there is sheared off grass/weeds floating, going slow will suck them up. Grass/weeds are not pushed aside as easy as wood debris either, and can literally go straight down the hull with some of the weed on one side of the keel, and some on the other, only to be fought over by the intakes when it gets there. Avoidance all together is the best option.
Scottintexas
Corinth, TX (DFW)
swatski
North Caldwell, NJ
MrMoose
Calgary, AB, Canada
Maaan... Thanks for re-posting that @jcyamaharider - I missed that story.
Brings some painful memories of me getting stuck in muck in the old (not-dredged) part of beautiful Kaskaskia River, IL... But that's another story for another time.
Does anybody know if "TX-DJ" made his way to this forum? He's a legend!
scokill
Rowlett, TX
The only times I've sucked something up it was going slow.
dan144k
Palatine, IL
Analyze it this way. If a 20' rope was floating on the water. Would you want to go over it fast or slow?
I would want to go fast. The slow vacuumed effect would be sure to suck up the rope.
robert843
Myrtle Beach, SC
I think at speed is the best but have sucked up stuff both ways. Anything I have ever sucked up at speed though has been able to be cleared by the reverse trick though. The hull displacement effect at slow speeds is reduced on the twin engine boats as the pumps are moved to the outside of the boat but the single engine boats I bet it works fine since the pump is in the middle.
swatski
North Caldwell, NJ
LOL - for sure!
The key word(s) in that example being "to go over it". If you must go over things - go fast for sure.
But if it is patches of small sticks and driftwood debris (what OP asked) found in rivers after heavy rain etc (the kind that's bobbing on the surface) - in my experience - it is best to go through it in full displacement mode.
__
robert843
Myrtle Beach, SC
There is s third school of thought if going at speed and you see debris in front of you just before you get to it slam the throttles into reverse and preform a submarine move and then have your crew remove the debris from the inside of the boat. No digging in pumps to get anything out and usually the ladies love it.
txav8r
I think TXdj sold his boat after the saga. Never again saw him in the place that shall remain nameless. And don't think he transitioned here with us. But he did give all of us a great education. I know exactly where he was stuck. I flew over it before he got it out. And I have watched the water recede a mile from there and then fill back full enough to encourage anyone to venture up that creek. That thread is a classic!
robert843
Myrtle Beach, SC
Ok now I'm curious about what happened what would I need to search to find that
dan144k
Palatine, IL
Yes from that that thread I learned my boat is not a jetski And if I get it stuck I will be screwed.
Our family ( with the jet boat, fortunately going slow) did get stuck once on the rock river, after the fact I looked it up and it was an hold bridge pylon. I try to be so carefully now.
Another tip bit,
I use to go up to the Wisconsin dell's on the river and we would go 300' 500' did not matter thru 2-3" of water at 45mph. It was awesome. But I realized don't try it with the jet boat. We also use to go in the spring when it was flooded and be wandering speeding through the woods kinda like we were on dirt bikes, but we were on Sea doo wave- runnners. Upper dell's.to the first day. Again it was so cool.
Speedling
Cedar Lake, IN
SS
At Lake Cumberland i noticed that if i went slow all the sticks and such would get sucked right in and i couldn't go a quarter mile without having issues. If i went just onto plane i could go the whole day with no issues.
swatski
North Caldwell, NJ
I think @robert843 should write a short manual on handling our boats. He obviously knows his stuff.
