To trade or not to trade?
Murf51
Franklin Furnace, Ohio
I've currently got a 2012 tundra sr5 4x4 double cab I bought a few years ago used. It currently has 53k miles on it. I like be the truck, it pulls the sx210 with ease (until you find a grade). BUT the mpg sucks! Best average I can do is 15mpg (80%highway). When towing I struggle to get 9 mpg. We tow the boat 2-3 times a month and our usual spots are 30min.- 1 hour away. Also, everyone complains about how stiff the rear end is on the tundra. I have found a 2014 Sierra 1500 sle all-terrain with a 5.3l that has 10k more miles than mine. I've been looking at it and have figured I could trade my truck and at least keep my payments the same. Would it be worth trading my tundra that's in fantastic shape for a truck 2 years newer with a smaller motor but better mpg's?
J-RAD
Orem Utah
We've got 2 trucks a '11 Sierra 2500HD and a '12 Tundra Crewmax. We use the Duramax for most of the towing but have used the Tundra a few times. You're right on when it comes to towing. The millage is awful.
That being said... I came from an '05 Silverado SLT with the 5.3L. I can't say it'd be a direct comparison due to the fact it had a 4" lift and 33" tires, which I'm sure effected it's performance... with that setup it actually didn't do any better than the Tundra. In fact the Tundra actually does better around town... You might average 16-18 MPG in a stock Silverado
I think if I were in the market for a 1/2 ton I would look hard at 3 different trucks. 1) Silverado with the 6.2L option that has active fuel management and better torque. 2) Ford F-150 Eco Boost. Good V-6 millage and the turbo helps out making some compatible torque figures. 3) Ram 1500 Eco Diesel. I had a guy tell me he was getting over 30 Hwy MPG... honestly the Ram probably peaks my interest the most...
So, I guess in my opinion, however significant, is that besides the fact that its newer, there's not a whole lot of advantage.
djetok
Edmond, ok
I have had both trucks and currently have a 17 f150 eco and traded a 15 eco in. I really liked my 14 tundra the most. I would have purchased a new one but they changed the cab. The tundra and few econ was not much worse than my 2 eco s. My 17 with the 10 speed is better but I really miss my tundra.
My 1500 that I had didn't pull my boat but did well with our old i/o that was heavy.
Murf51
Thanks guys, I'm thinking I may hold out and see how the new diesel in the f150 does. @J-RAD the ecodiesel also has my interest.
Betik
Frisco, TX
I run the numbers for you but I have done this type of calculations many many times. The savings in mpg does NOT justify the money needed for an upgrade. The mpg argument is either an excuse or make you feel better.
FYI: we have a Prius and we need to put over 80,000 miles to break even on the hybrid premium over a Honda Civic . Needless to say prius gets about 25% better mpg than the civic.
malibu Dan
Phoenix
Just about paid off.. thought about trading her in but honestly she does everything I ask of her and very comfortable to drive around...Honestly don't see a lot of other trucks as good looking..;)IMG_0600.JPG
2kwik4u
Georgetown, IN
This times eleventy bajillion.....The payback on something with better mileage is usually longer than most people own it. I've recently done the math on moving from an 13mpg running average to a 23mpg running average. Assuming 15k miles a year, its about $125/mo "savings"......But I would have to move from a $250/mo payment for 48mo remaining to a $500/mo payment for 90 mo.......check the total cost of ownership numbers there. Totally NOT worth the move.
But boy I wanted that Diesel jeep bad at the time, and was looking for any excuse I could.
veedubtek
Punta Gorda, FL
Scout
Actually, that's an important part of the calculation most forget. Resale is considerably higher as well and every time I've done the math, it didn't make sense *not* to buy a diesel (assuming an upgrade was in the plans no matter what)
2kwik4u
Georgetown, IN
If buying new anyway......Sure get the diesel. If buying JUST to chase mpg, it rarely works out.
blacksapphirez
Charleston, SC
SX195
Ecodiesel....
I never exceed 3000rpm towing. Quiet cab, get 16~18mpg towing my SX240 (5000lbs)
love it!
Betik
Frisco, TX
That is because you drive you like a grandpa.
blacksapphirez
Charleston, SC
SX195
ok i rephrase... i never 'HAVE' to exceed 3000rpm :)
