Looks great!Thanks for the heads up on the scupper @Julian .
How brittle was the plastic one?Thanks for the heads up on the scupper @Julian .
Its a quick process but a bit of a PITA. Not sure if there is a special wrench to get the nut on once the threaded part is installed. I had my daughter watch to make sure it stayed lined up correctly while I tried to squeeze my arms into that tight a$$ space. I did use 5200 sealant to seat the scupper valve and on the nut for the threads.Any issues with the installation?
My 2016 oem plastic scupper was not brittle at all it was in better shape than expected.How brittle was the plastic one?
