Tongue Scale Available in DFW ( don’t tow with 875lbs on the hitch )
Betik
Frisco, TX
So I switched to an aluminum trailer and I just loaded the boat on it. From the lake to the house I noticed the truck was bouncing like a kangaroo.
I checked the weight today and it almost 900lbs:eek:
I will move the post to take care it, but if anyone is concerned about his/her tongue weight and you are in the area, you are more than welcome to use the scale
robert843
Myrtle Beach, SC
How much was it and where did you pick it up I'm curious to weight mine since moving it back.
Betik
Frisco, TX
I will look for the receipt but @Mainah posted a link a couple of months ago.
The one I got was 0 too 1000lbs and it around $145 shipped
Mainah
Chapin, SC
Yikes more than double what it should be.
That scale is worth every penny as safety equipment IMO and that much weight may have busted two normal bathroom scales.
Sbrown
Easton, Pa
@Betik, I found a hitch cover for you
robert843
Myrtle Beach, SC
@Mainah maybe I can work something out to just borrow your on the Hilton Head run for a few minutes?
seanmclean
Medford, NJ
Bet you can rent that thing out for $30 bucks a pop and just ship it around like the scupper wrenches. I'd be in line.
Mainah
Chapin, SC
I will bring it along. Just bring a bike pump with a schrader connector.
Betik
Frisco, TX
I did not think about that....
Betik
Frisco, TX
How much is your tounge weight after sliding it back?
480lbs with about 18 inches backwards. I am estimating about 5,300lbs as total weight, but I will take it for measuring next weekend.
Betik
Frisco, TX
now it is still about 6 inches more forward than where yours is, but still 480lbs I can live with. 875lbs was crazy. I was in rush to move the boat because the buyer for my old trailer was coming in less than 24 hours.
I am making progress on the trailer though.
  • moved the post
  • put stolz bow stopper
  • replaced guide post with my old ones ( including the fabric around the PVCs)
  • installed LED on top the guide posts
  • lowered the fenders
  • installed Parkit360 driving shaft
still pending
  • weigh trailer/boat
  • move the post a little bit further back
  • replace middle bunks to 8 foot longs ( so it can catch and center the boat quicker and provide extra support
  • replace the capter on the rear bunks
  • adjust all bunks so the make full contact
  • install spare tire
kind of thinking to sale the 14 wheels and tires and replace them with 19 inch. The dealer said that it cannot be done, but I think I can do it :jimlad:
swatski
North Caldwell, NJ
Consider that may make it more difficult to launch the boat when using shallow ramps, or in low water conditions. Which is the primary reason, for me, to stay with the 14" for now albeit the 15" would probably be best overall, with good tire choices etc.
EDIT: I'm talking about the Shorland'r trailer, of course, I lost track of what you up to...
Scottintexas
Corinth, TX (DFW)
somebody, was it gmtech? had a good write up about upgrading tire size, with the distance you trailer at times it would be worth it,
where are you going to get it weighed?
Mainah
Chapin, SC
My guess is 5,250 lbs with that sweet aluminum trailer, two batteries, a nearly full tank of fuel.
Mainah
Chapin, SC
Yes it was @gmtech. Load capability increases greatly at 15inch and we are in the edge at 14 inch was the just of it. I opted not to buy tire covers knowing once my replacement radials start showing wear or rot I was going to replace with new 15inch rims and tires. That post you are referring to made me feel better about that decision. I have over a year on the 14 inch replacement radials and they are still looking good. Hoping to get a few more years out of them and by then I might have some serious tenfootitis.
Betik
Frisco, TX
I am estimated about 100 lbs more as I am planing to include a tower + spare wheel on the front.
The "aluminum" trailer has a dry weight of 1,240 lbs :eek:
