CraigAR
- Cape coral, Fl
Only got the wires ran and the towers up. Need to add my htx-6 to my amp board still and cut in 2 more speakers. Pulling the wires through the 17' ar240s tower was a PITA! I used marine 14ga wire that also had a sleeve over the positive and negative. Tried running both wires at the same time in the same hole as navigation wire that runs through the lower base of the tower outta sight with no success. Then tried running 1 at a time and couldn't get the 2nd one to fit. Finally I stripped off the outer sleeve to expose the 4 wires and taped all the ends together and bam.... wires pulled icon 8s installed.
