Tower Use
Hellacool
So, never pulled from the tower. Will begin this year, how does the rope attach? Over the Bimini, under the Bimini, close the Bimini? I have a 2016 AR240
subysti
east Longmeadow Mass
Over the Bimini with the rear poles set to the lowest setting.
Neutron
New Bern, NC
My bimini is tight like a banjo on the lowest setting. I dont like the idea of the rope rubbing on the bimini so i stow it away.
@subysti have you done it? And how bad was the rope rubbing
swatski
North Caldwell, NJ
I had the same issue, initially, but my canvas loosed up quickly and I was able to collapse the legs to the shortest positions.
The change in boat's attitude (bow up at speed) also helps - see some pics below.
So - in the AR/all small bimini models - definitely rope ABOVE the bimini when skiing, wake boarding, or pulling a tube. Otherwise you will be rubbing the end of the bimini off the frame from under.
Wakeboarding w/rope over the bimini (AR240, approx 18-19mph speed):
Wake surfing is tricky and will depend on where exactly you end up, behind the boat.
For example during (slow) wake surfing starts - the (short) surf rope will touch/ slide over the bimini rear edge hard; to save it, we use a sleeve that is sold as a trailer guide protector, got it from West Marine or BassPro. Learned that trick from my Super Nautique surfing friends who used to have the same problem in their boat.
Hellacool
Thanks for the replies.
