Towing a Jetski with a 242 Limited S-E
Krabi Sunset
Krabi, Thailand
When I get my new boat I will also consider getting a nice big Yamaha Jet-Ski to go with it.
Would you just tow the Jet-Ski behind the boat? How far behind? and would you have any concerns going WOT in a straight line on the ocean with fairly calm waters, with said Jet-Ski behind you being towed?
zipper
Boston Whaler
Krabi Sunset
Krabi, Thailand
zipper
Boston Whaler
The right ones could certainly lift it, but you would want to set it on a cradle on the swim platform. But not sure a 3 seater will fit up there.
Krabi Sunset
Krabi, Thailand
I think I'll stop pretending my 242 is a superyacht and that I can bring all my toys with me.
Jgorm
San Diego / Colorado river
You can tow it just fine. Add a water shut-off on the ski. Wot will be tricky, especially in the ocean unless it's flat. You'll want 100' of line to attempt that . The only rule when towing fast is never ever let the tow vehicle cross the wake. Never ever! Have enough line, and keep an eye on it. I would keep it under 30, probably 25. There is no way you can fit a 3 seat ski on the back without making tracks and a large hoist. I'd estimate $5k+ to have a mount made. I wouldn't do that, but I'd tow it somewhere if i was going to be there a while. You'll need a helper to pull it in and manage it while in as marina or docking.
I'm taking about a small 300lb ski, only 7'x<2'. A 3 seat , 11'x4' 900+ lb ski is a different beast.
Some interesting points in this article to consider....
https://www.yachtingmagazine.com/towing-fundamentals
Like reinforced towing tackle and tow points, "Remember that once you get under way with this rig, the yacht becomes a tow boat under the Rules of the Road navregs and the tender a towed vessel, so each must display the proper markings and lights for such operation"
boudin
Lake Livingston, Texas
I've towed skis at 20+mph, but only after blocking off the water intake. Put a fluid line clamp on the intake hose coming off the pump strainer... it'll be the hose on the port side of the motor with the Y flush adapter connected.
Everyone should carry set of fluid line clamps for towing of your boat, or another ski/boat should it be necessary. These work:
https://www.harborfreight.com/4-piece-fluid-line-clamp-set-65116.html
-Greg
njmr2fan
Augusta GA
I wonder, couldn't you have some type of semi rigid tow bar off each of the rear rings? Kind of the the way RV'ers tow their personal vehicle?
njmr2fan
Augusta GA
mrmeaniemeateaterman
Greenville, NC
I sense a homemade towdster thread shortly. Pics of pvc pipe and pool noodles will likely be involved.
Krabi Sunset
Krabi, Thailand
Boooo Ya
My friend, I owe you a beer. :winkingthumbsup"
LOL. Very true. They are not exactly cheap. But I don't mind, as they serve a wonderful purpose.
I think you could hack one together really fast with PVC pipe and some hammocks, but I am the guy who buys the Towdster and tips his hat to the creator for being so smart.
Krabi Sunset
Krabi, Thailand
Seems to work just fine.
I emailed Towdster and asked them which of their products they recommended for my 242 and a 750lbs 3 seater 12' long PWC. They said they Y shape not the V shape and sent me the above YouTube.
Jgorm
Just be careful. I've towed a lot of things on plane. It can get wild real quick whenever it decides to go down the wake . If they go side to side it can also generate extreme forces.
AlphaKap
Alpharetta, GA
I can just imagine the jet ski breaking free and flying through the back of the boat. No thanks.
