seanmclean
- Medford, NJ
- Limited S
I know many of you can thread a needle with your trailer, however much to my chagrin, I seem to have not been born with that gene. Couple that with a PITA driveway that requires a steep angle entry and navigating some trees with little clearance, arriving at home is the worst part of my boating day.
I took a stab at a lightning deal on a wireless waterproof backup camera. It's rated to IP67 (1m for 30 minutes), and though I'm sure it'll probably be closer to 1.5m when putting in - I'm hoping thats enough - time will tell. Got the camera for $60, so not a huge loss if I bet wrong.
Links:
Camera
Video Extension
Power Extension
All the wiring is run in the trailer except for the last couple feet which is zip-tied on. Grabbed power from the Blue (+12V in reverse) and White (Ground). Screen and Receiver are one unit, and powered just by a cigarette lighter - turns on as soon as it receives a signal when shifting to reverse. Will live in my center console except when trailering. Works pretty well for as cheap as it is. Might pick up a slightly larger antenna just to reduce interference (which has been minimal so far).
Links:
Camera
Video Extension
Power Extension
