Maccam26
- Winston-Salem, NC
- SX
i ask because I find that my bunks on 2019 SX 190 which are setup inside the strakes nearest the v of the hull are partially always curved because about 2-3 inches of each strake on the backside are under the bunk. Also, depending on final position exiting water I always have to check that my speedometer through hull is not under the bunk, it already bent the side protection on the out side of the sensor. So I can’t move that inwards even more.... maybe I can just slide the fronts in a bit to get the strake to clear. Or my second option is to move them 8 inches or so outward each but I have no idea where the stringers are in these boats for support. Figured I’d ask here before calling dealer as they are 2 hours from me. Thanks
