Ronnie
- SF Bay Area
- Limited S
I have a 2006 waverunner with a 998 cc, 140 hp, mr1 engine. It is the same engine found in the earlier 230 series boats. Over the last few weeks it's been giving me a check engine warning (light and sound) which would go away if I pulled the lanyard for a few minutes. My local shop ran their yds on it (for $106) and said the warning was a code 19 (low voltage) but the battery tested fine. To narrow the problem down would require a manual pin test for another $300 to $500. I know how to do pin tests for continuity and have an ohm meter so I decided to give it a try before dropping hundreds on what amounts,to exploratory surgery on my ski. This weekend it started when we checked it before launching but it would not restart when we got it to the ramp. This evening I switched out the rectifier but it wouldn't start, so a replaced the battery and it started easily so i ran it for 15 minutes on the hose. I figured I "fixed it", NOT! I couldn't get it restarted after that. Tomorrow I plan to replace the plugs and will more closely inspect the electrical system wiring and connections.
So the battery is good/new. The rectifier is also new. Other than a stator gone bad or corroded wiring any ideas on what could be causing this?
