Tubing storage when inflated on 2018 SX190
rayg1022
Anyone have ideas how or where to stow your tube or any inflatable on boat with out having to deflate and inflate over and over again especially when you have a full house on your boat?
Scottintexas
Corinth, TX (DFW)
it depends on what you want to do while the tube isn't being used, If I'm running around at full speed I have a short string that I loop to the tube and loop on the ski hook at the walk thru that keep the tube about halfway up the swim deck and it won't blow up and down,
If we're doing other water stuff at slower speeds I have a slightly longer string that I loop it to the mid cleat
brddog
Ditto. I do the same. Also, If I am staying in a relatively small area between pulling tubes, etc and anchoring I leave a milk jug filled with rocks dropped down with a rope that I hook the inflatables onto. Never had a problem with anyone messing with them.
BlkGS
Melbourne, FL
You could put it on top of the bimini top? That's sort of the issue of the 19 footers (and tubes in general), there just nowhere to out them. Even on my 23 foot we struggle with places for the inflateables with people on board.
Zizzou 192
NY
https://jetboaters.net/threads/new-ar195-with-questions.14516/
This thread has a couple pics of the setup.
I believe I have seen it in a similar position in Yamaha promotional material but I can not find a pic to verify.
I would guess that is the intended alternate use for the swim platform as otherwise it is a good chunk of space to waste while the boat is in motion.
WetWillie
Mount Juliet, TN 37122
I’ve found this to really be the only spot semi out of the way looped to cleat and ski tow handle and hung to one side to leave part of the step through and one side of the transom open for boarding until we anchor or deploy the tube for use...3667CD57-FCC4-4497-A830-425469E328A2.jpeg
jEt_jAk
SoCal
AR195
I use tube keepers and put in my swim platform.
LukePrinsloo
Fort Mill, SC
same issue on my 240. Granted I have that HUGE three person tube from Costco.
FYI when we launched on saturday I nearly flipped my boat or at least it felt like it. The tube was under inflated so it sucked water up onto the swim deck when I floored the motors.
at about 9 mph the bow swung up enough that my wife was hanging by a bow handle. Eased up on 9 mph and it did it again. I lengthened the rope on the tube but it was slowing the boat down as it was acting like an anchor when towing. (again underinflated). I filled it up with air and left it on the swim deck and had no more issues.
I love my sweeping tower but wish it was more like the E series tower so I could tie the tube up there.
Note: I have the huge tube because my kids are too small to be out there w/o an adult holding them.
2kwik4u
Georgetown, IN
Matt Phillips
Lake Tahoe
I have a couple of 2-person tubes that are about 60" in diameter. When moving about the lake with it inflated, I use a 6' bungee dock line as they have loops on both ends and stretch nicely. I hook one loop to the rear cleat, then string the line through a couple of handles, and attach the other end on the other cleat. That always holds it there ready for use when needed.
Here's a link to the line: https://www.amazon.com/AIRHEAD-AHDL-4-Bungee-Dockline-Feet/dp/B0012RJTUW/ref=sr_1_1?ie=UTF8&qid=1536087332&sr=8-1&keywords=bungee+dock+line
David Endrizzi
I tie mine on to the swim platform using a dock line. I loop the dock line through one of the rear grab handles in the rear of the cockpit, thread it through two of the handles on the tube and tie the other end of the dock line to the grab handle on the other side of the boat. I leave it lose enough so that the tube is on the swim platform and not coming into the cockpit at all.
swatski
North Caldwell, NJ
Not the best pic of it, but I have had an extra cleat installed here (red arrow in the picture) for tying up tubes - in my last 190 and the new 240.
Works great for tying up a tube, inverted, onto the swim deck for transport, never an issue with cruising (at any speed). The ski hook is too far back for those large tubes not to overhang.
BigAbe75
Litchfield, IL
@swatski is that cleat reinforced? Is that just 2 bolt holes and a surface cleat or did you put in a retractable cleat?
I have some interest in more info, if you think about it sometime when you’re on the boat. (Don’t make a special trip, though). :)
OrangeTJ
El Dorado Hills, CA
Don't know for certain whether it would work on your boat, but on ours we put our tube up on top of the tower/bimini when not in use. Best spot we've found to get it out of the way.
seanmclean
Medford, NJ
Yet another clever Swatski idea. I may need to look into it.
My current setup is to just lay the tube on the swim platform up against the seats. I run a dock line from cleat to cleat through the handles. Has worked well for me, but a bit awkward to tie it up.
swatski
North Caldwell, NJ
This is a simple plastic cleat bolted through w/no reinforcements. Obviously - not meant for towing, or mooring, just to hold an inflated tube down. No issues w/years of use by now.
