As crazy as it sounds I have an educated guess (wiring diagram from other model) that the port tach on most Yamahas that display gps speed is also responsible for some canbus communication. Having communication errors thrown up all the time would be less than ideal.
You could put them both behind the dash and use the NMEA 2000 hook up to a chart plotter that shows the info it could free up both holes on the console.
