Unresponsive touch screen
Hector
Mechanicsville , Virginia
almost everytime I use the boat I have to recalibrate the touch screen. Is anybody else having this issue?
Once I do it at initial start up, im good for the rest of the day regardless of how many times I toggle the ignition switches on/off.
I cut my batteries off after every use and disconnect the black vsr wire when I'm charging my batteries overnight before using the boat.
Dont have that problem at all. I wonder if disconnecting the batteries has something to do with this?
Check the connections in the back of the screen in the helm compartment. This is consistent with a problem I had when I first got our boat. The issue was caused by a loose connection.
Didn't think about that, will check tomorrow when I bring her home.
Thanks
