Very Basic Newbie Question
Slfmde
I've never driven/piloted a boat. I just had an AR240 delivered from out of state so I didn't get to ride along on the setup.
My question is: when reverse is engaged and I turn the wheel to the left does the stern go to the left? I was under the impression it was the opposite. I will have to reverse out of boat launch and want to be prepared
Also does no wake mode work while in reverse because the manual only mentioned forward or I missed it.
Thanks!
CraigAR
Cape coral, Fl
When in reverse, the direction of the steering will turn the boat in the same direction. I have a 17' ar240
djetok
Edmond, ok
You turn left in reverse the stern will go left, the bow will swing right.
No wake mode in reverse. I believe it does but have never done that. I don't know if I would. I usually reverse very slowly as the control in reverse is not like a car. Plus you don't have brakes.
Slfmde
Great thanks guys.
haknslash
Lake Martin, AL
Moomba
Yes no wake mode works in forward or reverse so long as you don't go beyond the first detents of the throttle. I use it all the time when docking or retrieving as it allows me to focus on steering with plenty of thrust for maneuvering.
Scottintexas
Corinth, TX (DFW)
Please, please make your first trip on a calm, uncrowded day with only expectations to practice
Maybe make a post and ask if there's a member close by that could go with you
Never go faster than your willing to hit something
Slfmde
Thanks for the advice. I'm on the bay and fairly large river so it doesn't get congested. I have some friends with experience willing to go out with me.
djetok
Edmond, ok
I think that a calm lake with little to no current is more what Scott was referencing. I have been around boats all my life but this is my first jet. We went to a small lake on a weekday. The worst thing you can do is get frustrated. Keep calm and slow.
NewBoater
Virginia Beach
Just go very very slow around docks until you get hang of it. Just creep in barely moving feathering it to forward, neutral and reverse as needed to creep up to a dock. I like a very slight bump forward then back to neutral then same thing over and over till I'm real close then cut both engines off and tie it up. Engines off as you get real close helps as you don't hit gas trying to over correct. Good luck!
djetok
Edmond, ok
Hope you had a great first outing @Slfmde
