anmut
- 212S
How do I explain this - it's near perfect? Set the speed or (for cruising) the RPM either manually or by setting up rider profiles. Turn on (while boat is in N), select profile or RPM speed. If wakeboarding the driver will pop the rider out of the water, throttle up and past the speed setting and RS will beep and alert that it's taking over and then it'll throttle it back down to set speed. To change speed while towing, just adjust the knob one way or another to adjust by .10 of a MPH.How much can you notice it throttling the engines during wakeboarding? When I was out with 8 adults, above 18 mph it would start to plane out then at 20 once more hull is out of the water it would shoot up to 25. Throttle back down, rinse and repeat. Really annoying. I'm wondering how hard the PP will have to work to prevent that from happening.
When being pulled, I'll feel the pop out of the water like normal, then the surge to get up to speed, then just as fast the boat will calm down and I'm carving at 18mph no matter what conditions are or how deep into a turn we might be. 18.miles.per.hour.all.the.time. It's pretty awesome!
