Wakebooster pin replacement
Skott1576
Out surfing today, went to switch sides with the booster and the pin that goes thru the stern eye broke off the teather.
Anyone know where I can get a replacement?
Skott1576
Can anyone give me dimensions? I'm going end up making one just need overall length and diameter at large end.
Scottintexas
Corinth, TX (DFW)
iamcalled
Carrollton Texas
I can get you dimensions this weekend. I should be going out Friday if the weather works out.
Levi Weatherford
Murray, KY
I don't know if these are detailed enough but it's the best I can do right now.
Levi Weatherford
Murray, KY
I would also like to know where the tether broker. This has been my biggest fear. The cable doesn't look real beefy.
Skott1576
Those are great. Tether didnt break, after looking at the pics the socket head cap screw that holds that mounts the pin to the tether backed out.
Pricing everything thing out, I should be able to make a new one fairly cheap.
Was also able to get a part number today.
F3F-F84AB-V0-00
Need to call dealer and check out the availability. They are not cheap.
Skott1576
Is it aluminum? Pretty sure it is but having a hard time remembering. I'm gonna end up making one out of steel.
Mike Cardillo
Rochester NY
195S
I wonder if filling the center with foam spray would make it float.
