Warranty is about to expire
RIDINwithRICK
Good morning, I have a 2016 FSH 190 and my warranty is about to expire June 16 2021 so I would like to know if there is anything I should have my dealer check out that is under warranty and would benefit the longevity of my boat. Any suggestions or advice will be appreciated. Thank you in advance!
2kwik4u
Georgetown, IN
My '17 AR190 expired it's warranty last year.
I talked to the dealer about it a little bit at the boat show the year before, and his only suggestion at the time was to do a "pre puchase inspection". This is the same service the offer for anyone wanting to buy a boat from an individual. Essentially climb all over the thing, check everything is working and in good order, read the hours and check codes, then recommend any fixes/upgrades that might be relevant. Essentially a marine survey, but through a dealer instead of a surveyor. Said it was a flat $125 fee for a '19ft boat, report would come with pictures and a small write up on condition and any issues documented.
If you're really worried about it, something like that might not be a bad idea. I didn't do it, and just kept on running with the boat. No major issues up to 162hrs now going into my 5th summer with it.
Like all things YMMV.
FSH 210 Sport
Tranquility Base
The pre purchase inspection thing sounds like a great idea. But if you are one with the boat it’s unlikely an inspection would turn up anything that you didn’t know about!
2kwik4u
Georgetown, IN
100% agree, and the reason I didn't go through with it. I had a good idea of what they were going to find anyway, so why spend the cash, right? :D
FSH 210 Sport
Tranquility Base
How many hours on your boat? Have you kept up on all the maintenance?
FSH 210 Sport
Tranquility Base
Right! Just have to try and stay ahead of it... doesnt always work that way, but perfection is a direction not a place.
RIDINwithRICK
Boat currently has 403 hours on it. I usually do all the maintenance myself because dealer would take forever just get it back here in Miami. I change the oil, spark plugs, and change the air filter. At the moment, the speedometer is not working. It goes up to about 10mph and that's about it.
2kwik4u
Georgetown, IN
The speedo on these boats are pretty simple. Check the little wheel on the bottom of the hull towards the stern on the port side. If it's damaged/loose then speed won't read properly.
FSH 210 Sport
Tranquility Base
Right on..... sounds like your “ride” is solid! Will the warranty cover the speedo?
RIDINwithRICK
I'm not sure if the speedometer is covered on warranty. I have to check that out. How many hours with good maintenance can these engines last?
FSH 210 Sport
Tranquility Base
If you have the 5 year YES warranty I’d think it would be covered..
I don’t know how long these motors will last but I’m hoping a few thousand hours! I would think that as long as the oil and filters are changed regularly, and if they don’t get overheated they should last a long time.. the thermostats are pretty cool at 158* if memory serves.
