water getting in somewere 2016 242 x bilge pump going steady
Brad Dunn
British Columbia
Hello I am getting water in my 2016 242. sitting at dock the bilge pukes out a gallon every minute. It is getting in somewere. were can i look as this is scary, bilge pump dies or battery dies we will fill with water.
Where should I look. Common spots. How to fix?
thanks in advance
Sx240
Grand Rapids oh
Did you forget the drain plug or maybe it came loose also I see on here people talking about a scupper valve and replacing it with a stainless steel one it’s located under the swim platform it’s a one way valve lets water out but shouldn’t let water in good luck finding the issue
Brad Dunn
British Columbia
No the plug was in. But thanks
Sx240
Grand Rapids oh
Check the scupper valve then search on here there are a few threads on it
Sx240
Grand Rapids oh
Quite a few people have had problems with them the oem ones are plastic and break
johhnyboat
Ocean City, MD
Did you every diagnose the issue? I have the same boat and I have done just about everything and still getting in water. I have one more thing to try but I have to take the access panel off and it can wait until the end of the season. I just may take it to the dealership at that point and have them look.
