ourlee
- Hopatcong NJ
- Cobalt
- Jet Ski
Is there a dealer network or just one source?
thx Rick
thx Rick
Do you offer a military discount?We sell direct. Thanks for the kind words from everyone! We wouldn't be around if it weren't for y'all.
It's $0.99 less than you quoted.Is it really worth the $1449.99?
$0.99! I stand corrected!!It's $0.99 less than you quoted.
We have an active duty military discount - send me an email at info@hydrophase.com.
If you do any sort of water sports towing (surf, tube, ski, wake board, etc), it's worth every penny.Is it really worth the $1449.99?
As of right now we do a lot of tubing, and my boys are getting interested in Wake surfing. I mainly like to cruise on the ICW and plan on trolling offshore.If you do any sort of water sports towing (surf, tube, ski, wake board, etc), it's worth every penny.
Ah, that would make sense for the GPS accuracy. Yea I usually troll between 5-7 knots, so 5mph min would be fine.Might need Justin to verify, but I think there is a minimum speed/rpm that RideSteady will go. Maybe 5mph when the system kicks in to control the speed? Since you mentioned trolling I just wanted to point that out just in case that speed was too fast for your trolling needs.
The minimum set speed is 8 MPH. Could be a bit fast for trolling. 4000 is the minimum settable RPM speed (in RPM mode).Might need Justin to verify, but I think there is a minimum speed/rpm that RideSteady will go. Maybe 5mph when the system kicks in to control the speed? Since you mentioned trolling I just wanted to point that out just in case that speed was too fast for your trolling needs.
Ridesteady won't overcome your throttles levers slipping. If they slip, Ridesteady will slow down. It will, however, allow you to set your throttle levers in a more forward position where they're less likely to slip.As of right now we do a lot of tubing, and my boys are getting interested in Wake surfing. I mainly like to cruise on the ICW and plan on trolling offshore.
It sounds like exactly what I need, the factory cruise control is hot garbage and my throttle just slip and slide when every they feel like it. Very frustrating.
I haven't had the opportunity, but I'll have to one day!ever see Shakey? an austin boy
I got in early so I paid a bit less, but we use it literally everytime we're out for one watersport or another. I'll never stop recommending it to people. GPS speed control is essential for boarding, surfing, and skiing. Think of it as though you just save $10-14k in an E-Series and even more when you factor the divorce... it's a worthy investment!Is it really worth the $1449.99?
