Jeff L
- California, Maryland
- Limited S
Thank you. Forgive my lack of knowledge, but where does that lead to?Just a rubber gasket to keep fish and the like from swimming in there while docked.
Your exhaustThank you. Forgive my lack of knowledge, but where does that lead to?
Thank you muchYour exhaust
good to know thank youAlso, don't be concerned when a ring of dark colored silicone falls out of there. Just a little extra from the factory that will eventually break itself loose.
what did you use for epoxy?Looks like the silicone already came out. I did not like the raw unfinished edge of the cut out which is below the water line so I epoxied over it to seal it from absorbing water.
Yep. Just another example why I would not want to wet slip those boats unless I had to. It's FRP, but still basically raw fiberglass and will blister.Looks like the silicone already came out. I did not like the raw unfinished edge of the cut out which is below the water line so I epoxied over it to seal it from absorbing water.
Good to know. I found one and was a little spooked.Also, don't be concerned when a ring of dark colored silicone falls out of there. Just a little extra from the factory that will eventually break itself loose.
