What boat lift weight is needed for a 19ft model AR190 also a 24ft if I bought one of those?
spaceman2
Looks like I will need to have a new boat lift installed at new home so wonder about the lifting weight needed for the lift and maybe some ideas
on the brands that people seem to be using today. I guess its going to be a four post lift. Most seem to be the
four post lift models. Going to be in Saint James City area of southwest Florida coast.
Russ C
Haymarket, VA
I installed a 4000 lbs lift for my AR190 (2147lbs dry). It lift it with no noticeable strain with 30 gallons of fuel, toys, and 4 adult still in the boat. I have a overhead lift so I cannot provide an opinion on 4/2post models.
biffdotorg
Pelican Rapids, MN
Check the sticky on model specifications for all boat models. Look at the wet weight. (minus trailer of course) Most will say you want the wet weight to be no more than 3/4 the capacity of your lift. A lift salesman should be able to confirm this when you are buying.
We put our 242 on a 5000lb lift for this reason based on it's wet weight. I would consider that a minimum lift for the 242's. We use removable aluminum lifts here in MN as we have to pull them due to ice each year. But capacity and wet weight apply in both situations. Trust your dealer for sure.
Good luck,
swatski
North Caldwell, NJ
I think my lift is rated at 6,500lbs, it works very well with the AR240 but I would not want to have anything less. My thinking is, you always want to have some buffer in case of water intrusion, icing, whatever.
captras
Lake Livingston, Texas
New boathouse and the lift for my 242 is also rated at 6500 lbs. More than enough to lift the boat with gas and even a few people in it.
spaceman2
What are the prices of the boat lifts running 6500lb versions here on southwest coast of Florida I wonder. Any brand names?? What features to look for on them? Saint James City, Fla area
captras
Mine was custom built here on Texas for $3200 for the cradle only, not installed.
spaceman2
Thanks for the reply. Maybe will get some in this area.
