What is the diameter of the washout drain on 2017 FSH?
Matt Wetzel
Spring Park Dr., Winter Garden FL 34787
FSH Deluxe
Hi all,
I’m going to try to use the cleanout drain as an entry point for my x-ducer cable. Of course I’ll need to splice a “Y” or “T” connector on the drain hose. Hence the question regarding the diameter.
Any help is appreciated and the boat is not easily accessed to check for myself.
Thanks a bunch
Matt
Matt Wetzel
FSH Deluxe
So the drain that goes from the clean out comes out on the starboard side of the area where the nozzle exits the stern. One other owner snaked the transceiver cable through this exit port then put a t- connector inline to the drain hose.
This allows the drain to remain intact albeit with a t-connector and the transceiver cable exits th “t” where the transceiver cable came out the “t”. If I can get the diameter of the original drain then I can order the right size without having to Park the boat in the driveway while I’m off to the hardware store or west marine.
See the video here.
