Where to buy raw Seadek?
McMark
Monongahela, PA
Is there a good source for raw Seadek? Either in roll or maybe 4'x8' panels (or however it would normally be available).
Google search brings up a couple options -
Ebay, Overtons, or you can even get a quote directly from SeaDek
@McMark you can buy single color SeaDek in 40X80 sheets but the two color stuff is not sold to the public. SeaDek closely guards their proprietary fabrication methods and don't allow their two color product to get out there without their stamp of approval on the fabrication. We can help you with either single color sheets or if you want to do something more custom we can help you there as well.
Thanks guys. I'm suggesting to a group at work to use Seadek where folks come in contact with a piece of equipment while they are running it. Is the single color textured and brushed the exact same material as the two color teak looking brushed Seadek?
@McMark yes it is the same. The only layer together two 3mm sheets vs one single 5mm or 3mm sheet. All comes with peel and stick adhesive.
You're welcome!
