- Corinth, TX (DFW)
last time I pulled my trailer I noticed I had a light issue,
all marker lamps worked
only right tail light worked, no stop or turn signal
no left tail, stop or turn signal
I had remembered last year I didn't have a light or two but just chalked it up to a burnt bulb and was going to replace them later. Well now is the time,
I made sure I the 5 pin on the truck was working correctly and sending power.
I bought a new LED unit and cut the old left light assembly off temporarily connected the new LED and now I have no lights at all, no makers or right side either. I tried the old assembly on a 9v battery and they still did not work so I feel confident the sealed unit is bad.
I ran a direct ground wire from the grounding point at the front of the trailer where the 5pin connector grounds to and the LEDs work, I also pulled the first marker light and hooked up the direct ground and it worked also.
I took some sandpaper and shined up surface where the ground was previously attached at the rear but that didn't help.
Why did I loose all my lights units when they are each grounded separately?
Why can't I get a good ground at the rear of the trailer when I even sandpapered the painted surface to bare metal?
any help would be greatly appreciated,
