I'm speculating here, but I don't think the 1.8 Non-supercharged will have the power to spin the 160mm pump and aggressively pitched impeller that is found in the 195 boats. I suppose you could get the impeller repitched to "standard" 1.8 specs, but I don't think there is any data or experience on how that will perform.If i swapped the ecu , and left it non supercharged would this work because getting the supercharged engine seems very few and far between
Yikes, sounds pretty rough. Both in terms of damage and cost. Insurance helping at all?Yes I called it was ridiculous like 12,000 k and the engine is toast machine shops could not rebuild it destroyed everything multiple things let go ...
Yeah. It's probably around $1500I wonder what the no core charge would be.
