Worx pump cone
martynnz
New Zealand
Hi,
I thought i'd post my "limited" experience with the Worx pump cone. I got one to see if it improves hole shot esp pulling my heavy ass out of the water. Buying and shipping a lucky 13 cone to New Zealand is expensive, whereas the Worx are made in Australia so easier to get. The other improvements I have made on the AR192 are: SVHO intercooler, ribbon delete, worx high flow strainer and K&N filter.
Installation is the same as lucky 13 cone. I used EP 00 grease as it was the closest I could find to enpoc.
photo 1 is the two cones side by side:
Here it is mounted. You could mount without pulling the pump out but I was changing the strainer at the same time:
Speed tests: Both done at 11 degree Celsius air, 18 deg water temp and average of 3 runs (all GPS).
Before: 0-50kph 10.8s, top speed 77.7kph
After: 0-50kph 9.4, top speed 79.4
Not sure I can tell the difference between seat of pants but time will tell. Video below is a side by side of runs.
<iframe width="560" height="315" src="https://www.youtube.com/embed/NSuEG5ai_6U" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Cheers
Martyn
jinsonkv
Moomba
HO Impulse
Yes you are right Buying and shipping a lucky 13 cone to New Zealand is expensive. Is there any alternative option to new zealand?
yam240sx
is this cone suppose to face upward or downward ? ...thanks
martynnz
New Zealand
Hi,
I have mine facing up which is the same direction as the original (you can see it is slightly asymmetric as well).
Cheers
Martyn
