WS420 Install - 242 Limited S
renrab
Hey all,
Any suggestions for WS420 mounting?
I don't really want to cut the fiberglass out for this...
As of last thought I will prob just install on a board beside amps under helm.
swatski
North Caldwell, NJ
Hey all,
This is where I had mine mounted in a 190. Worked great.
renrab
You had to drill a hole I assume to run all the RCA's through? Looks clean though.
Rod5
Marietta GA
255XD
IMG_0720.JPG IMG_0719.JPG Yes small hole behind for RCA's and power.
swatski
North Caldwell, NJ
Correct, if I remember correctly I ended up using a 1" hole saw drill and fit a rubber grommet. Plus small holes for mounting screws.
