YDS 2pro - 2013 later YDS reader available?
BoaterGuy
Have check engine light again, hoping it's not my O2 sensors again.
Anyway - I found this YDS kit for our late model boats. Apparently, after 2012, the interface changed. Do I really need to spend $300 to read my engine code? I tried going into the diagnostic screen on the tach by holding the M button then scrolling through the menu, but it is saying Normal under engine codes and does not give a meaningful fault code.
YDS 2PRO -
Yamaha Waverunner outboard diagnostics
Anyone have any ideas? I'm in the Mid-Atlantic region in Baltimore if anyone wants to do me a solid. I just cant take it back to the dealer right now.
Engine runs fine, just throws a warning every 5 mins.
Thanks!!
Neutron
New Bern, NC
I wasnt aware there was a yds for newer models.
BoaterGuy
@Administrative can you maybe move this or link me to the answer? I was unable to find my answer in a search. Maybe move to general or somewhere else?
Scottie
Helena, Alabama
BoaterGuy
Thanks let me know.
Neutron
New Bern, NC
I am curious as well. I do side work on a lot of Yamaha outboards, boats, and skis. This would be great to have if it works on new stuff
Beachbummer
Houston TX
Looks super promising! I've been very thankful for cheap YDS available for my 2008. It will be very positive to have this for newer boats too!
Scottie
Helena, Alabama
Unfortunately I blew up a rear bearing on my port side impeller this afternoon, so I'm down an engine, and ordering parts. It will be a couple of weeks now before I can test the YDS. Sorry guys, but I will get to it eventually for sure.
BoaterGuy
Damn! How the he’ll did you do that? Sorry dude!
Scottie
Helena, Alabama
Yeah not fun. Parts begin arriving today though and she'll be better than before by the end of the weekend.
BoaterGuy
The tool just arrived today. Hopefully can get to scanning over the weekend. Now to figure out how to plug it in...
Neutron
New Bern, NC
Let us know how it works, and any details about what info that it collects.
Scottie
Helena, Alabama
Same plan for me. Boat is back up and running as of last weekend, so I was planning to play with the YDS tomorrow.
BoaterGuy
So I finally got over to the marina and found the diagnostic ports buried deep in the crazy wire area behind the helm.
Plugged everything in and it says it can’t see the ECU. I tried bumping the starter and even running the engine. The system would just keep cycling saying it sees the boat and then not and then again. But anytime I catch it for the few seconds it can see the boat and select Read Data, it gives the ECU not found error. It’s a little different from the old scanner stuff as there are no comm ports to mess with and it always is able to recognize the device when I plug it in the USB port.
I sent a message to the seller on eBay and he wants screenshots of the error. Not sure what that is going to do but i will oblige.
Basically a waste of money so far....
Scottie
Helena, Alabama
Did you unplug the tachs?
Scottie
Helena, Alabama
This is from the service manual. It applies to the Yamaha factory YDIS 2.1 system, so I assume it applies to this aftermarket connection as well.
102267
BoaterGuy
I did not. Thanks, I’ll give this a shot.
BoaterGuy
@Scottie thanks for the tip. That did the trick. The tool worked great and I was able to read all the codes and look at the engine monitor. The fault code that was last triggered was code 206. Which of course is unlisted in the Service Manual I just purchased from the Yamaha pubs site. I also found a spreadsheet that someone posted Trouble Code Link and it is not listed there either.
Also, looking at the O2 sensor readings on the diagnostic - The good engine has a reading of ~.9 for both O2-1 and O2-2. But the trouble engine has a reading of ~2.3 for O2-1 and .3 for O2-2. Not sure if that is due the engine not being warmed up or what the reading should be at normal operating temp. I dont have a chance to run it on the hose right now.
BoaterGuy
A follow up for this.... I couldn’t locate the definition of trouble code 206 so I just cleared the codes and ran the boat for an hour. Nothing came back. Fingers crossed that it is fixed.
Overall the tool does what it says it will do. Just make sure you disconnect the tachs before hooking it up. (Thanks Scottie)
