Yds info
Benoit
Attica NY
Does anyone have the proper fuel injection interval numbers? Length of firing in milliseconds
djetok
Edmond, ok
Benoit
Attica NY
I’m having a running rich issue with starboard motor. Yds shows twice as long injector opening as port.
djetok
Edmond, ok
Benoit
Attica NY
On all 4 cylinders. Tops of pistons are black like the plugs. Which are new this year. Port side pistons are grayish with clean plugs
Benoit
Attica NY
I swapped ecus last night. Will hook up yds to see if the injector #’s went with them tonight
Benoit
Attica NY
Swapped ecus and fuel pumps. No change on injector duration. 6ms on starboard. 3-3.5ms on port. Not sure how ecu decides this timing but must read something like a vehicle uses a maf sensor
buckbuck
Texas
I have a 2008 and had a Throttle Position Sensor go bad. It had an effect on the timing at idle. You may want to consider that.
Beachbummer
Houston TX
Did you save the output? Can you post it?
Benoit
Attica NY
I can’t post output. Just a couple bad pics30A10108-D14C-4C58-9343-459B5BF3EEBB.jpeg9D4B3867-5FEB-43CF-A52A-A932B6EB11FE.jpeg
Benoit
Attica NY
I will check tps
