Rv6kitfox
- 242 Limited S E-Series
Connext display issues, I’ve read through the forums.
When house and start batteries are turned on:
-the blower will randomly come on for 3-5 seconds then it goes off…or it does not come on at all. The 5 minute timer however does count down regardless.
-The navigation/running lights come on
-the display may or may not show voltage for the batteries.
-joystick controls don’t work
-Error messages as seen in the pics.
-Both engines start right up
-no tach displays
-no F/N/R displayed
-Depth readout on display is blinking
Last pic is the display with the engines running.
Although the volts on the display don’t change, the batteries they at 12.8V when off and 14.1V when engines are running.
Although both batteries tested good I replaced them anyway with brand new.
-I disconnected and reconnected every plug under the helm and in the engine compartment.
-I removed and checked ever fuse inside the engine compartment back well in the fuse panel
-I Checked the CAN fuses under the helm
-Disconnected the GPS plug and reconnected
-Disconnected BCU plugs in engine compartment and reconnected.
-Removed the battery switches by the batteries and and verified all connections were proper and tight
-Tried the ‘reset’ by turning the battery switches on and starting the engines for a couple minutes the shutting down and repeating multiple times.
-Tries disconnecting and reconnecting the batteries multiple times.
Best way to check grounds?? Main cables travel from battery compartment to engine bay on Port side??
I’m at a loss at this point, thanks in advance for ANY suggestions.
![IMG_7226.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/220/220238-4029c3116b6c67f3aef1c2b440dad34e.jpg)
![IMG_7227.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/220/220239-347daf7a313a982c9e730b04322a50c1.jpg)
![IMG_7223.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/220/220240-d4341692d95924bc69604e990fdf6cb1.jpg)
-no tach displays
-no F/N/R displayed
