2020 yamaha vx overheat and check Engine Light on
Banu118
Jet Ski
PWC
I took ıt 2 nd day to water drove like 2.7 hours started beeping overheated and went to limp mode Then friend of mine towed me over to the dock took home and flush ıt . It dıdnt beep or anythıng the ı took ıt to dealer they couldnt fınd any thıng fırst day then they dıd baytest and ıt dıd overheat again nothıng sucked to ıntake . Anyone wıth same problem ????
anmut
212S
Can you run it on the hose without it overheating? Pull the impeller?
Banu118
Jet Ski
PWC
You can run it with hose there is no over heat i did flush nothing happened dealer did the same thing Nothing but when they put it in the water for bay testing overheated again .
this much over heating damages the engine too idk what are they going to come up with ...
WREKS
Port Saint Lucie, Florida
Have you run it in shallow water?
