Did they specify its the longer bolt to be used on the top gunnel vs side mounted? I don't remember the specs on the bolts they sent me after I order it. Maybe they realized that and started sending the longer bolt from the get go.
Did you decide about extensions? and type? Plates would require even longer. Cylinders just the regular longer screws.
I do like the way it leveled it. But certainly could go either way. Just dont want you to drill and then not be happy with it.
I was shocked how easy it was for a machine shop. He just went in back and came out with piece of solid aluminum rod. Said, we will cut it, tap it on both ends, order a threaded rod same thread as what came with tower so will thread in tower and polish.
But I gotcha, plate would likely work too.
I just completed my 192 & decided to side mount to get the correct angle of teh tower. This also gave me the same bimini coverage as the factory bimini.
The install is done took one entire day but I only had one helper for half the day. I used 1/2 wood below the deck and those longer bolts are absolutely necessary. I am now debating on what method I want to use to get the tower more level. I am still thinking a spacer under the bracket since I am pretty much out of room in the garage. That would require even longer bolts for the rear bracket but I am sure I could source those.
Will the back of the tower sit flush with the back of the boat if you raise it up 2-3ft? I’m about to order my tower and I don’t have much clearance in my garage behind the boat.
2020 sx195. Mine folds back. Had 4 in risers made to level at a local machine shop. I used some plywood in addition to the supplied plates. Monster sent me longer screws. Mine does hang off back a bit. But needed to go back to fit in garage.
Will the back of the tower sit flush with the back of the boat if you raise it up 2-3ft? I’m about to order my tower and I don’t have much clearance in my garage behind the boat. I plan on having the spacers made this week once the tower arrives. Thanks in advance!
