Berkey Jet, new impeller needed for high elevation?
I couldn't find much information on it but curious if putting a lower pitch impeller if would it help me get out of the water more quickly in higher elevation. Any advise or help would be great. I don't care about my high speed as much, just hoping to get a single skier out of the water easier, seems to drag a bunch more up here to when pulling someone out of the water.
My boat is a 1978 Tahiti Mini day cruiser with a 460 ford motor in it. I bought the boat off my father, were it was ran at close to sea level in California. Now being at higher elevation I am trying to figure out how to make the boat more efficient with the loss of power. I already had to adjust the carb, re jet it and adjust the vacuum secondary to get it to kick in. Still seems to be having some lagging issue not really due to any motor lag it sounds good at WOT but doesn't seem to be getting full RMPs I remember reaching, running at sea level. Motor is maxing out at around 3800 RMP here in Colorado and its been awhile but I believe it was closer to 4300 or 4400 RMPs we would hit in California.
I know of a lot of boats here they adjust the pitch on props to achieve this but just hoping someone might know more then I about impellers and if it would, one help me get out of the water quicker and two might get me the extra RPMs. I don't know the pitch on the impeller currently in the boat, I haven't taken it apart want to see if it might be a good solution before I get into the work.
Top Bottom
