Garmin 94 sv+ FSH 210 install and Transducer works great
HangOutdoors
Royal Oak, MI
Allright two sets of pictures, mounting to the ride plate. First is just straight mount to it. Second set is using a 3/4" spacer. It is wood in the picture but I have Black King Starboard I could use and round off the ends. It drops it another 3/4" down from the ride plate. I am showing the stock mount, but I do have the stainless steel mount which arrives tomorrow to use if it appears better.
I want to get the true side vue (scan) as well as read at speed. Not sure about turbulence or other issues. I figure I will just use Marine silicone in the hole for the cable in case I need to move the transducer.
Any and all advice and criticism is welcome.
HangOutdoors
Royal Oak, MI
HangOutdoors
Royal Oak, MI
JASmith
Minnesota
There are some great ideas here. I've got an idea... I'm not sure if it's great, or just stupid.
What if I used this style of thru hull... Garmin GT41-TH | Thu-hull Transducer
I was thinking maybe 6-12" in front of the drain plug. it comes out to nearly the same shape as the keel (haven't measured) and would be a single transducer that wouldn't get washed out under any circumstance that I've been able to imagine, it's the lowest point on the boat for maximum viewing angles and smooth water, accurate depth/temp... Lots of Pros.
Cons? structural integrity? drainage? maybe more potential for dragging it on something...
HangOutdoors
Royal Oak, MI
I looked at that personally, and didn't like a lot about that spot. First take a look at the back of your boat and the cross member on the trailer, not enough clearance or awful close. I don't want to raise bunks and adjust the winch tower, etc. Also the through hull screws are going to be in the drainage channel. Sooner or it is going to hit something. I really wanted to like the position, I just couldn't. Plus as they come out with better transducers I want to be able to change them if I so desire, this could present an issue in this position.
If you can wait a few days, I am fabricating a mount out of aluminum and it will mount on the ride plate on the Port side, where my mockup above is. The Starboard concept is not going be great, I don't think. I just got back from Home Depot for aluminum channel and stock, 1/8" thick. I am taking inspiration from @Julian and his mount. I like it. I don't have to drill into the fiberglass. Can cleanly remove it or change to a different chart/plotter or remove If i sell the boat easier. Also If I hit something good the aluminum will tear off (working on a kick up type idea as well) without ripping out fiberglass. Also I could raise on lower it while adjusting by the side arms. I am going to use SS bolts initially and test out on the water. Then I found a local shop who can weld it for me if I want.
Link to his pictures below.
https://jetboaters.net/threads/my-2016-yamaha-242x-thread-more-photos-added-6-14-19.9464/post-384483
JASmith
Minnesota
That could definitely work... I like that. I didn't think of dropping it that far down. And another Pro is I could make a mirrored one on the other side for the LiveScope transducer... oh man.
Good thoughts, thanks for the link!
HangOutdoors
Royal Oak, MI
I will post pics and materials and measurements in the next couple of days or so. I really want to be on the water on Saturday, 62 degrees here :)
JASmith
Minnesota
How is it working out for you? my boat comes back from storage in a few days and I'm excited to get to work on it!
HangOutdoors
Royal Oak, MI
Pick one is the side pic 2 is from the rear pic 3 is when the clamp lets loose and the aluminium your cutting jumps on the chop saw and you need 8 stitches
JASmith
Minnesota
Yowza, that looks a little painful. I took my middle finger nail off with a vegetable peeler once (bourbon was involved) and can relate.
The install looks good! Haven't had her on the water yet I don't suppose?
HangOutdoors
Royal Oak, MI
No not on the water yet. I used bolts so i could replace the arms and change the length.
crazy4life
I just installed my 93sv on thursday. Mounted the transducer to the ride plate all the way to the rear. Works great.
JASmith
Minnesota
Nice!
What's directly behind the transducer? just something temporary?
crazy4life
Nice!
That is a straight edge. Had the wife take a picture from the side to make sure the transducer was parallel to the hull. Good thing I did that because by eye it was way off.
HangOutdoors
Royal Oak, MI
Nice!
What about Side Vue/Scan? Your transducer bottom is higher than the keel and rudder seems like it would interfere? I dropped mine lower for that reason. How close does the rudder get to it fully turned? What is the white stuff? Is it Sealant? Why did you use it there?
Have you water tested it?
crazy4life
tested it yesterday and side scan was the first thing I checked. Worked flawlessly. The transducer is mounted all the way to the rear of the ride plate. Top of the transducer is even with bottom of the keel. I was interested to see if it worked. Also was pleasantly surprised that everything worked up to 49 mph. Couldn’t get to 50 but it’s not like I didn’t try.
White stuff is 5200 because u can only get 1 bolt in the mounting bracket where it is mounted.DBEAE468-05F2-4090-89D1-7BE59332DFB5.jpegAC0F3A4A-BC7E-45DD-BD7F-399B8BAE91BA.jpeg
HangOutdoors
Royal Oak, MI
In your picture it is showing higher than the keel. Do you have a rear picture showing the height?
Also it looks like we have different transducers, which model trans is yours?
