212s
- 1000 Islands
- 212S
I was a bit confused at first too, but when I had it in the driveway later in the afternoon I noticed the thin red box around the items. I couldn't see the red box the first day out in the bright light because I didn't know what I was looking for from the manual's description. But now I know what I'm looking for on the screen, it's easy to see and now controlling it is easy.Thanks so such 212s!! Lots of good info! I definitely need to go through the manual for the touchscreen.
Right, 7th pin in the center is the correct one for the 7-way, end one for 5-way. I've never used mine though and don't intend to use it so I have no idea how silent it might be.Last night I confirmed my truck’s 7th (middle) pin is working. It immediately showed 14V when shifted into R. Listened by the trailer when plugged in numerous times and never heard anything, if the solenoid is engaging it’s silent and hasn’t worked the first two times out. It has to be the trailer.
Here's a test, when using the lockout key, you need to make sure you're not on a downhill slope or the trailer brake actuation will push rearward and you won't be able to get the key in the slot. At this point your brakes are already engaged and you can't back up. You need to be slightly uphill or on flat terrain and then just tug the trailer gently to pull the surge actuator forward and release the brakes. You can then pop in the lockout key. Perhaps your trailer brakes are already engaged when you're trying to activate the backup solenoid? It doesn't take much movement to get the brakes engaged.
At the ramp area when we're prepping the trailer before lining up to launch, I park off to the side either on the grass a bit or near a slight uphill grade. This pulls the actuator forward with the truck hitch and the key goes in no problem. Sometimes it's completely flat where we're prepping and after I stop, the key won't go in so I give the truck a light and brief tap on the gas to pull forward a couple inches to release the brakes.
If you're using the lockout key on the tongue, bring along some masking tape and use it to hold the key in - if not as soon as you pull forward the key will fall out like it's supposed to, and you can't back up. The magnetic lockout key fixes this and looks better than tape.
