Oil spray
Diezel
Hey, my buddy is having a problem with his port engine, it’s spraying oil from somewhere behind the engine. He can’t figure out where it’s coming from or what’s back there that would cause it to spray out. Anyone have any ideas? Thank you
Diezel
Sorry its a 2017 242 limited s
WREKS
Port Saint Lucie, Florida
Valve cover gasket? No experience with that engine but over filling MR-1s can cause oil pump to push oil into breather lines causing increased pressure in crankcase leading to pushing out semi-circular gasket flaps. image does not show them but, I think there are also two in the back.
Diezel
Would that cause the check engine light to come on if he over filled it with oil?
Diezel
And the low oil pressure light came on and the engine shut off
WREKS
I do not know. I would start by looking inside air box.
Levi Weatherford
Murray, KY
I had to replace the rear seal/magneto cover seal on my 2017 212 Limited S at the end of last season. Only had 80 hours on it. I caught it before it really let loose but it would slowly leak oil out of the seal and the crankshaft would sling it under the pto cover and onto the floor. $13 part. 3 specialty tools needed. Engine has to be removed.
Diezel
Hey Levi, when it happened did your low pressure light and check engine light come up n and your motor shut right down?
Levi Weatherford
Murray, KY
No it did not. I caught it whenever it just started to leak. So the oil level never got down low enough to give an oil light or shut down. It never actually blew out totally. But what little oil that it dod leak was sprayed all around the rear of the motor.
Diezel
Thank you sir I appreciate all your help
