On the water Help User Group - Join to Help or post @HELP when you are in urgent need
swatski
North Caldwell, NJ
@HELP
Trying to install my lateral thrusters on my new sx190. Removed the snap ring and the bolt off the rudder but can’t get the shaft in the articulated keel to release.. only got it down about 1/8”.
Any help is appreciated
I can't help much, but just be careful not to get too forceful with the rudder/AK - it is made of some weird alloy and relatively easy to break.
Farmdog267
Lansdale Pa
Pulling the back apart now.. thanks
JetBoatPilot
Event Sponsor
Event Sponsor
Vendor
Panama City, Fl
Yep that's what I was going to do. Call tomorrow if you can't get it loose. 850-867-1410
Farmdog267
Lansdale Pa
Got the rear portion off and the pin out. Hopefully good from here. Thank you
Farmdog267
Lansdale Pa
All done. Back together and seems to operate as it should on the trailer. Test it out tomorrow. Will have pics when not on my cell! Thanks again for the help!
Wisefam22
Lake Lanier ga
@HELP had the stereo off and was on beach all day. Motor wont turn over all the way to start. Just need a jumper box? Any other options?
bronze_10
Raleigh / Wake Forest Area..
If u have a battery switch change it to both.. If only one bat then yes.. Sounds like u need a jump
justason
SWAG Forum Lead
Check terminals on batteries Crank tight
Wisefam22
Lake Lanier ga
So my 18 month old pulled the lanyard, my wife put it back in and appeared to be on all the way. Had to use knife to lift it higher then set back on the lanyard and it started fine :/
JDFester
Loganville, GA
Towing another boat with AR190...
Ok to do it? Similar sized boat; have a few miles to go. How fast is ok? Would like to get them back before dark...
JDFester
Loganville, GA
Not used to driving slow; normal to see steam/exhaust at swim deck? ~5mph...
4x15mph
Downingtown, PA
Other boat a non jet boat? If jet, either go no wake speed only or have them clamp off water intake hose(s).
How are you towing them? Side by side or pulling with a line behind you and connected how? Lots of stress on any cleat but varies depending on the waves that you are crossing
JDFester
Loganville, GA
Non-jet; brothers 19’ v Hull. Calm lake, with no tow service.
JDFester
Loganville, GA
Would love to get up to 12mph if it would be safe for my boat/engine...
Eric Ballard
Clayton, NC
They are responsible for their boat; go as fast as you feel comfortable. spread the load if possible across 2 cleats. it's not a speed issue for me but rather a load issue. watch out if going above no wake if its rough water. Dynamic load is what will break your boat.
0627Devildog
Classifieds Moderator
Acworth, G.A.
Have him trim all the way up if possible to reduce drag. While the tendency to go as quickly as possible to get back before dark, the primary goal is to get back. I wouldn't put too much strain on the boat by trying to go above no-wake mode (especially on a single engine).
Eric Ballard
Clayton, NC
it won't hurt your engine but could hurt where you have the other boat tied off too. I'd use the trailer tie down points if possible.
jawsf16
I would use the trailer tie down points to tow. All passengers in your boat except maybe one. Keep people looking forward and in bow if possible. Lines can snap and hurt people
In either boat. Go slow. Take your time.
haknslash
Lake Martin, AL
Moomba
Yes, especially under load.
Go slow. It's not worth hurting your boat or making things uncomfortable for either parties in the boats. It's not a race. Yes towing sucks but best to do it slow and safely.
