Push Button Start Mod - It works! With video and full instructions
spaz1868
Lake Lanier, GA
Great job @Mainah! I've wanted to do a push button start and have most of the parts needed, just have not found the time to do it. I do have one question for you about the boat wiring. Do you know what the white wire is for? I know what all the other wires are for except for the white wire. Trying to figure out what role it plays in starting the engines.
sstegh
Menomonee Falls, WI
That is awesome!! Well done!
Trevor Shipman
Charlotte, NC
Just to be clear, this will work on a 06 ar210 too right? I don't have all the fancy computers and what not on mine.
spaz1868
Lake Lanier, GA
I believe I figured it out after going over your diagrams and applying a little common sense. The brown wire activates the starter when + is applied to it and the white wire turns off the engine when - is applied to it.
Mainah
Chapin, SC
Bingo. +12vdc to Brown activates the starter solenoid and ground to white the magneto kill. Make sure to keep the each engines brown and white seperated from the other engine. That is the reason for the two relays for both start and stop.
Mainah
Chapin, SC
I don't know on that model. In theory if the wires have the same functions it should.
David D
Westerville, Ohio
SX192
Awesome @Mainah. I officially wish I was an engineer now.
Mainah
Chapin, SC
Fixed the links in the pdf. FYI when saving a power point document with copied links as a pdf remove the http:// from the front of the links so that they start with www
Trevor Shipman
Charlotte, NC
Part of the problem of going in half on a boat with your brother is all mods have to be agreed upon. I think this mod is so bad ass and we usually agree on stuff... He hates it. Thinks it's stupid. So there goes that. Man do I wanna put it in though!
kthrash
Madison, MS
could you not have both engines crank at the same time? or is that too much for the batteries to handle?
Mainah
Chapin, SC
@kthrash - From an earlier post ...
I forgot to mention that while possible to start both engines simultaneously with this mod as opposed to in sequence by changing the timimg on the realys I strongly recommend against it. The starters place a very high load on the batteries and wiring so there is a risk of melting battery or starter cable if not done as this mod is layed out. There are other concerns such as battery load on a weak battery preventing staring as well. Lastly sequenced is just plain cool in my opinion.
spaz1868
Lake Lanier, GA
@Mainah, thanks for the motivation for me to complete my own push button start mod. Mine is a little different than yours because I wanted just 1 key with a push button start to each engine. I also added a single engine off button so I can kill both engines at the same time without having to turn the ignition key off. Turning the ignition off with the key also turns off both engines. Here's some pics of my setup:
I moved the single ignition key to the tray under the radio because I did not want to make any holes that were permanent. I also put the engine kill button on the side of the tray. If I wanted to undo this mod, all I would need to do is replace the tray and there's no traces of this mod ever being made.
2016-05-29 17.54.59.jpg 2016-05-29 17.55.11.jpg 2016-05-29 17.55.18.jpg 2016-05-29 17.55.44.jpg
This mod is not only for the cool push button factor, it is also practical. The keychain float that I have on my keys always rested in the cup holder right below the ignitions so it got in the way of my drink. Now, the key and keychain are both out of the way.
Mainah
Chapin, SC
@spaz1868 - Sweet!!!! I assume you did this without the timer relays and instead used standard bosch style such that each engine only cranks as long as its start button is pressed? Great example of another way to accomplish this for the use case and design that you desired. Those halo buttons sure are cool if I do say so myself.
So that everyone else knows what model and year did you do this on? Do you think my method would work on that as well? I can confirm your method would on 2015 and 2016 connext models without push button start.
spaz1868
Lake Lanier, GA
Yes, just 3 bosch style relays and 3 buttons. The whole mod cost me just $20 along with probably 1 hour wiring everything up.
This is on a 2012 AR210. Your method should work for my year boat because all the wiring was exactly like your diagrams.
kthrash
Madison, MS
I gotta do this, so sick of the long beep every time you turn the damn keys..
Ryan Cassidy
I didn't notice that... so this gets rid of that damm beep... Now that you mention it, it's not in the video. That's worth it all together!
Ryan Cassidy
Ordered all the parts for this today. Will start the install when we get back from Vacation. will post back on an 2010 SX240 install.
Topper232
Marlton, NJ
Limited
@Trevor Shipman maybe you install one push button for your engine and leave the key for his? :confused:
Gym
Falmouth, MA (Cape Cod)
