Beachbummer
- Houston TX
- SX
Ez lock, then you will never have a blow out. Once was enough for me.
I see that your exhaust is rapped with something with foil on it. Was that a factory thing or a mod?Exactly what Julian said. It's mostly the water coming up over the rear deck on decel. Sealing that cover is vital though, the stock "seal" is worthless. Heck, half the screws in mine were stripped out when I got the boat brand new. I replaced all the screws with stainless nuts and bolts, and also cleaned all the silicone sealer off and replace it with a rubber seal. My rear compartment went from always having water in it to being darn near dry on most times out just by making sure that cleanout panel is sealed properly. I actually also screwed down the little access cover since it falls off half the time anyway. Anyone that's getting too much water in their bilge or rear compartment should make sure that panel and access cover is totally sealed.
You can see the seal in this pic...
*****UPDATE*****
I had 2 posts for this issue and provided updates in the other thread a couple weeks ago already, but, for closure, I'll provide the same update here as well.
Dealer identified the issues as:
(1) Rub rail along the back of the boat wasn't sealed at all. He removed it and sealed all screws when he reinstalled it.
(2) Both exhaust ports were "gushing" water. He replaced both seals and said issue should be resolved now.
Now, if I can just get some decent weather, I'll take the boat back out on the lake and confirm effectiveness of countermeasures.
Did you remove the silicone that was there or just ad the PVC weather stripping?View attachment 68629 View attachment 68630
I have the same issue, with a dog that has to go swimming every time we go out. Water in the back compartment every time.
I added 1/4" thick x 3/4" wide neoprene foam with adhesive one side to the under side of the screwed down access cover. I also added 8 more screws to hold it down. It sure seems like it will work, but I haven't tested it yet.
