Brian_NY
- 252SD
The reverse gates are off on my 2017 SX240. The boat was purchased brand new and apparently it has been an issue since new. The port gate and the starboard gate are off by 3/4" in neutral position. This is causing the boat to circle slightly and is making docking a bit more tricky than it should be.
Can someone let me know what the specs are and at what throttle position.
Thanks in advance
Thanks in advance
