Throttle Sync set up with Perfect Pass
Sparty
Jackson MI
Heard about Forum from Will at JetBoatPilot.com and I really want to order his Throttle sync but not sure how to adjust since I have perfect pass installed. I did not install perfect pass myself and I do not want to screw anything up
I would appreciate any help in this
Bob
farrelltravis
Vendor
Norman, OK
I am not going to be of much help here, as I do not have either one of the items you are discussing.
However - anyone else have an answer? I, personally, wouldn't think Throttle Sync would interfere with PP as PP is more computer controlled, right?
jetboater4life
Rochester, MN 55901
I have both. I installed my perfect pass and am still fiddling with it a little. Mainly keeping my throttle wires free from binding and playing with the 10mm nut on the throttle cable linkage to keep the RPMs the same. I only tried PP a few times without throttle sync but felt that the RPMs were more in sync with throttle sync. If you have PP working well then I wouldn't hesitate at all to use it with throttle sync. I did it for a good half the boating season last year and it worked great.
Sparty
Jackson MI
Derek thanks so much for the feedback. My RPM seem good with PP but when just running on my own the right engine is just lagging a little so I was not sure how to adjust cables and not mess PP up
jetboater4life
Rochester, MN 55901
All you need is a 10mm wrench to adjust the RPMs with perfect pass. It's actually pretty easy. I'm still tinkering with mine. I can document it with a picture or two when the weather warms up, but I believe it is right in the manual too. Another thing to note is that if you get the RPMs to match at one speed they may not match at another, so as long as it's close I'd call it good.
Sparty
Jackson MI
makes sense...yes I need to get rid of new 10 inches of snow first
appreciate your response
Bob
